Date/Time: Tue, 26 Nov 2024 18:49:20 +0000
GetACSDrawingByLineNumber / GetUserDrawnDrawingByLineNumber
View Count: 261
[2023-11-01 12:28:54] |
User907968 - Posts: 823 |
Since updating to version 2561, I am seeing problems when the following functions are called from studies built prior to version 2545. sc.GetACSDrawingByLineNumber sc.GetUserDrawnDrawingByLineNumber More often than not, the program crashes immediately when using studies that call these functions. Debugging in VS suggests that the stack is getting corrupted. To test a very basic example, the attached code was built for version 2484. Everything works as expected in 2484, but running the same study in 2561 causes the program to crash. Observation: After calling sc.GetUserDrawnDrawingByLineNumber in version 2561 - 1) The size member of s_UseTool changes from 952 to 992; and 2) The version member changes from 2484 to 2561 Neither of the above happens in 2484, even when running studies built on much older versions. |
DrawingTest.cpp - Attached On 2023-11-01 11:50:01 UTC - Size: 2.31 KB - 254 views |
[2023-11-01 13:41:28] |
Sierra_Chart Engineering - Posts: 17182 |
We are checking on this.
[2023-11-01 16:37:32] |
This has been resolved in the latest release.
[2023-11-01 16:42:20] |
Perfect, thank you, very much appreciated.
