Date/Time: Tue, 26 Nov 2024 16:29:12 +0000
BUT: ACSIL UTF8 characters with new graphics functions not working
View Count: 640
[2023-11-01 07:33:38]
erwinbeckers - Posts: 22
I'm trying to draw some UF8 symbols on my chart like arrows, circles, rectangles but the new graphics functions don't show them
Here is a small snippet of what I'm trying to do:
SCInputRef bar_marker = sc.Input[0];
if (sc.SetDefaults)
bar_marker.Name = "UTF8 symbol";
bar_marker.SetString(u8"➘");
sc.p_GDIFunction = on_render();
void on_render(HWND WindowHandle, HDC hdc, SCStudyInterfaceRef sc)
sc.graphics.SetBackgroundMode(TRANSPARENT);
sc.graphics.SetTextColor(0xff0000);
sc.graphics.SetTextAlign(TA_NOUPDATECP | TA_LEFT);
auto bar_marker = sc.Input[0].GetString();
sc.graphics.DrawTextAt(bar_marker, 100,100);
[2023-11-01 22:45:39]
Sierra_Chart Engineering - Posts: 17182
We tested this and it works but only with GDI. You need to disable OpenGL.
[2023-11-02 00:15:17]
any plans to make it work with openGl as well?
[2023-11-02 02:32:36]
We do not think this is going to work well. It would hurt performance to support so many characters with OpenGL.
[2023-11-02 04:31:42]
User719512 - Posts: 264
I would use DrawPolygon, DrawRectangle, DrawEllipse/DrawEllipseWithRadius, MoveTo/LineTo and create any shape you want either based on origin or center of a rectangle of size X. Create a few helper functions and draw whatever images you want at BarIndexToXPixelCoordinate and RegionValueToYPixelCoordinate. The math involved is not terribly difficult.
Attaching a crude drawing to visualize the idea... Happy coding!
imagegdi arrows.png / V - Attached On 2023-11-02 04:30:33 UTC - Size: 14.61 KB - 95 views
[2023-11-02 19:13:20]
That is indeed a workaround, but I would rather have it just working with openGL as well
[2023-11-03 18:04:57]
Arrows were pretty fun to build. Your post inspired me to add these to the other things I started working on now that GDI can be used with OpenGL (which finally makes doing this work worthwhile).
imageSierra GDI Arrows.png / V - Attached On 2023-11-03 18:04:18 UTC - Size: 2.62 KB - 99 views
[2023-11-05 01:17:21]
LudaTrades - Posts: 27
That's great, any chance you have an example study for this or similar? I'm trying to play with the opengl graphics but GDIExample.cpp has compile errors for deleted functions, so I'm a little lost.
[2023-11-05 02:53:49]
LudaTrades, I filed this ticket with Sierra since I assume you are using Remote Builds.
Remote Build for GDIExample.cpp gives errors about use of deleted functions
I build from Visual Studio, and everything is working fine. I have no insights into why the Remote Build server is busted.
[2023-11-08 23:09:13]
This is fixed by the header file updates to add constructors for the affected classes in v2563.
