Date/Time: Wed, 27 Nov 2024 02:34:45 +0000
Incorrect curency value per tick in FXCM CFDs
View Count: 987
[2014-07-22 06:49:55]
User25311 - Posts: 32
There are a bug in the profit/loss calculation for many CFDs. I think the problem is in the "Currency Value Per Tick" value for the symbols.
For example in the Sierra Chart default setup the FRA40 CFD have a 1.0 "Currency Value Per Tick", but if we look in the FXCM product guide we see that the FRA40 have a 0.1 value.
If I change manually the tick value for the necessary symbols the problem looks solved on the Trade Activity Log. But when I open a trade the problem remains in the real time p/l calculation, in the chart. For example when a I have a real (in the broker) open loss of 10€, the chart shows a loss of 100€.
Any solution?
Date Time Of Last Edit: 2014-07-22 06:50:56
Private File
[2014-07-22 07:26:27]
Thank you for pointing this out. We have corrected the Symbol Settings.
Update them by following the instructions here:
https://www.sierrachart.com/index.php?page=doc/doc_GlobalSymbolSettings.php#UpdateSettingsSteps
Be sure to apply them to the existing charts.
