Date/Time: Tue, 26 Nov 2024 18:22:24 +0000
[Programming Help] - ACSIL feature request - custom drop down menus
View Count: 272
[2023-11-01 07:21:38]
erwinbeckers - Posts: 22
Hello Sierra Chart,
Would it be possible to allow developers to add a custom drop-down menu for their studies which can be easily accessed directly from the chart?
I know there is the option to add a menu item to the right-click chart context menu, but that's not very flexible. you cannot add sub-menu items or textboxes inside the menu item
We use dropdown menus a lot in our ninja trader indicators (see example screenshots) since they provide a very nice user experience
Especially with the more complex indicators it is nice to have a quick dropdown menu to quickly turn on/off some signals or adjust some its settings
regards
Erwin
imagefpmenu.png / V - Attached On 2023-11-01 07:20:40 UTC - Size: 68.98 KB - 85 views
