Date/Time: Tue, 26 Nov 2024 18:14:27 +0000
Data feed not working after upgrade to 2561
View Count: 354
[2023-11-01 00:37:53]
User329455 - Posts: 19
I received a message when opening Sierra that I must upgrade to version 2561. After doing so, all of my charts display the following two messages and the data feed doesn't work at all (it's frozen around 3:22 PM EST):
1) Real-time market data only supported with Sierra Chart data feed for symbol: F.US.EPZ23 ID:1 Click for symbol information.
2) Download Failed. Historical data only supported with Sierra Chart data feed.
I've always used the Denali data feed.
[2023-11-01 01:20:08]
User620552 - Posts: 19
I am having the same issue when I logged in right now.
Was working earlier today and stopped working after it forced the update
[2023-11-01 01:36:14]
Sierra_Chart Engineering - Posts: 17182
Regarding post #1:
Set "Global Settings >> Data/Trade Service Settings >> Common Settings >> Allow Support for Sierra Chart Data Feeds" to Yes. If you have changed this setting, then reconnect to the data feed after by selecting 'File >> Reconnect".
[2023-11-01 01:37:00]
Regarding post #2:
Activate the exchange that you need here:
You have no exchanges active.
[2023-11-01 02:44:50]
The underlying reason for this problem has been determined and is now resolved. Disregard our prior postings.
