Date/Time: Tue, 26 Nov 2024 18:49:06 +0000
Unable to load data
View Count: 240
[2023-11-01 00:12:43]
tuanluu20902 - Posts: 24
Hi there, over the weekend, my charts have been unable to load the latest data. The image lists the reason why but I am confused because from searching other posts based on the errors, I have already done what I was supposed to do so why did I suddenly get this error over the weekend.
I use CQG with Amp brokerage.
imageScreen Shot 2023-10-31 at 8.09.49 PM.png / V - Attached On 2023-11-01 00:12:24 UTC - Size: 88.51 KB - 75 views
[2023-11-01 14:24:01]
John - SC Support - Posts: 36300
Check the setting for "Global Settings >> Data/Trade Service Settings >> Common Settings >> Allow Support For Sierra Chart Data Feeds". It sounds like this is set to "No" for some reason. Change it to "Yes", then select OK to close that page and then select "File >> Reconnect".
If the above is not the case, then we need to see your Message Log by following these instructions:
Close all of the Chartbooks with "File >> Close All Chartbooks".
Open a single chart for the symbol you have an issue with through "File >> Find Symbol". Tell us that symbol of the chart. Tell us about *one* symbol only.
