Date/Time: Tue, 26 Nov 2024 18:14:20 +0000
getting delta totals on my footprint chart
View Count: 253
[2023-10-31 00:35:20]
User143402 - Posts: 9
Would someone be able to assist me on how I'm able to get delta totals on my footprint chart?
Thank you
[2023-10-31 14:57:51]
John - SC Support - Posts: 36300
If by "Delta Totals" you mean the delta for the entire bar, then do the following:
- Add the "Numbers Bars Calculated Values" study to your chart.
- Add the "Study Subgraph Above/Below Bar as Text"
- In the "Study Subgraph Above/Below Bar as Text" set the Input for "Input Study Subgraph" to be the Numbers Bars Calculated Values study and the "Ask Volume Bid Volume Difference" subgraph.
- Set the rest of the Inputs for the "Study Subgraph Above/Below Bar As Text" as you want.
You can hide the "Numbers Bars Calculated Values" study if you do not want to view it directly.
