Date/Time: Tue, 26 Nov 2024 18:42:31 +0000
Trades export with commissions
View Count: 264
[2023-10-30 20:39:22] |
User333366 - Posts: 10 |
I have set the commissions for my instrument in Global Settings >> Symbol Settings (also ticked the box "Use Custom Symbol Settings Value") In Trade >> Trade Activity Log, I ticked the box "Use Commission" And when I look at the "Statistics", I can see commissions have been correctly applied, but when I then go on and export my fills, there is no information on the commissions exported. Did I do something wrong or is the export functionality just not including this on purpose? Thanks for your help |
[2023-10-30 22:07:44] |
John - SC Support - Posts: 36300 |
You state that you are exporting your order fills, so these will not have any commission information associated with them.
[2023-10-30 23:22:26] |
can i ask why that is? I dont think i am understanding the logic behind it (or I am used to seeing those in other platforms)
[2023-10-31 14:26:30] |
The order fills do not have any P/L information in them. They are just the specific trades that took place. These fills are combined in the other pages for the log to actually give you the P/L. Since they do not have any P/L themselves, there is no commission that can be applied.
