Date/Time: Tue, 26 Nov 2024 18:44:29 +0000
Headless support for Replay
View Count: 289
[2023-10-30 14:42:33]
User985352 - Posts: 1
I was wondering if there is any support for headless replay or general Sierra Chart interaction? My goal is to run multiple replays one after the other with slight modifications to ACSIL studies in between each replay. Is there some way to kick off a replay from the command-line?
Date Time Of Last Edit: 2023-10-30 14:42:45
[2023-10-30 16:24:06]
John - SC Support - Posts: 36300
Not from the command-line but you can do control replays using a custom study. Refer to the following:
sc.StartChartReplay()
