Date/Time: Tue, 26 Nov 2024 18:25:42 +0000
Merging 2 Different Existing Charts in One Chartbook
View Count: 415
[2023-10-30 10:24:09] |
User925417 - Posts: 22 |
Hi My Profile and 5 min chart both in one chartbook then Footprints is in the other chartbook. Would like to put all 3 charts in one chartbook to practice Backtesting or review in replay. thanks so much |
[2023-10-30 15:47:57] |
John - SC Support - Posts: 36300 |
You can not directly combine chartbooks. You would have to duplicate the charts to a single chartbook using the command "Chart >> Duplicate Chart to Chartbook" or "Chart >> Duplicate All Chart to Chartbook". Refer to the information starting at the following and the section below it: Chart Menu: Duplicate Chart To Chartbook (Chart menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-10-30 20:17:55] |
Thank you so much Sir sorry Sir the next question is how come the 5 min chart is not in sync with the Market Profile and Footprints when i put on Replay? Did change the contract to June so i can go further back. and i only put the date on Replay on july 3?thanks again Sir |
[2023-10-30 20:29:06] |
if i replay at July 3, both Market profile and Footprint on the same day so they are in sync however my 5 min candlestick chart is at 23rd of August?thanks
[2023-10-30 22:03:09] |
First, make sure that all the charts have the same symbol and the same amount of data loaded. If you need to go back far enough, then make sure that you are using a "Continuous Futures Contract" for all the charts. Refer to the following: Continuous Futures Contract Charts Then, make sure you are using an option on the Chart Replay Control Panel to replay either "All Charts in Chartbook" or "Charts with Same Link Number". If you are using the "Charts with Same Link Number", then make sure that the charts all have the same link number so they will replay together. Also refer to the following: Replaying Charts: Preventing Loss of Synchronization Between Different Charts During Replay And also look through the rest of the information on the above page for Replays. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
