Date/Time: Tue, 26 Nov 2024 18:49:41 +0000
Mistake in documentation and no warning in build
View Count: 258
[2023-10-29 21:58:49] |
japatu - Posts: 1 |
Automated Trading From an Advanced Custom Study: sc.GetTradePosition Example. int Quantity = PositionData.PositionQuantity;//Access the quantity
correctly double Quantity = PositionData.PositionQuantity;//Access the quantity when it compiles from remote with int, there is no warning -- Starting remote build of Custom Studies Source files: bandziorek.cpp. 64-bit -- 22:30:16
Allow time for the server to compile the files and build the DLL. The remote build succeeded. Writing file to: C:\SierraChart\Data\bandziorek_64.dll -- End of Build -- 22:30:22 Build with Visual C++: [vcvarsall.bat] Environment initialized for: 'x64'
bandziorek.cpp C:\SierraChart\ACS_Source\bandziorek.cpp(151): warning C4244: "inicjowanie": konwersja z "double" do "int", mo�liwa utrata danych Trwa tworzenie biblioteki bandziorek.lib i obiektu bandziorek.exp Trwa generowanie kodu Zako�czono generowanie kodu -- End of Build -- 22:28:19 |
[2023-10-29 22:22:59] |
Sierra_Chart Engineering - Posts: 17182 |
This is not really incorrect because in all cases, the quantity is going to be an integer which is actually safer to work with. There is no trading service Sierra Chart works with, that would work with a double. We will not be changing the documentation. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
