Date/Time: Tue, 26 Nov 2024 18:39:19 +0000
visible windows when switching between charts
View Count: 286
[2023-10-29 21:13:17] |
Shlomi.B - Posts: 42 |
I always have more then one chart-books open at once but when I switch between chart-books the windows/charts inside that chart-book don't become visible until I click each window tab. only then they take the screen. How can I sort it so when I switch between charts the windows in that chart take "center stage”?. The "window always visible” option doesn't do it. and the "always on top" option is grayed out for me. please help and thank you in advance. |
[2023-10-30 00:06:46] |
Sierra_Chart Engineering - Posts: 17182 |
Are these attached or detached charts that you are having an issue with? The problem may also be operating system related. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-10-30 00:06:56
[2023-10-30 02:20:59] |
I have some charts attached and some detached. im running parallels on a mac.
[2023-10-30 14:40:57] |
If you are not using Windows, then this is further indication this is going to be an operating system problem and we do not know how to help you with this. One thing to try to do is to use Window >> Cascade and save the Chartbook. See if that helps. We cannot help further. This is an operating system problem. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-10-30 14:41:26
[2023-10-30 15:05:41] |
thank you for your help. love the platform!
