Date/Time: Tue, 26 Nov 2024 18:33:42 +0000
Daily Range Study during intraday
View Count: 346
[2023-10-27 01:55:29]
User846000 - Posts: 27
Hi Support,
I have followed what I think is the correct order of operations for intraday Daily Range study (based off custom session Daily bars), it seems to work on static data meaning if I load the charts and SC is not connected to live data. However once the market comes online with live data the study disappears, so is Daily range meant to be only on historic data bars and will not update on intraday data?
My aim is to calculate the Daily "exhaustion" which means I need to know in real time once the range of the intraday instrument (I overlay the Daily Range onto a smaller time frame chart) range has been exceeded.
Thanks for any advice in advance.
Tim
[2023-10-27 14:22:56]
John - SC Support - Posts: 36300
Exactly what study (or studies) are you using?
