Date/Time: Tue, 26 Nov 2024 18:19:12 +0000
Sierra Charts Crashing in Simulation Mode - Need Assistance
View Count: 263
[2023-10-27 00:53:06] |
User751739 - Posts: 29 |
Hello, I've encountered an issue with my Sierra Charts. When I launch the application in simulation mode, it crashes. However, it seems to run smoothly when I start it in safe mode. I've tried looking in the CrashReports folder for any logs or indications of the issue, but there's no crash report available. Could someone guide me on how to determine which custom study might be causing the application to crash? Thank you for your assistance! |
[2023-10-27 13:31:01] |
Sierra_Chart Engineering - Posts: 17182 |
This is explained here: Sierra Chart Unexpectedly Shutting Down | Memory Errors | Unusual Software Problems | Exception Errors | Freezing of User Interface Also update Sierra Chart to the current version: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
