Date/Time: Tue, 26 Nov 2024 18:44:25 +0000
[User Discussion] - The prices presented by DOM
View Count: 363
[2023-10-26 20:43:01] |
User670703 - Posts: 1 |
Hi. I recently installed SIERRA and noticed that the prices presented by the DOM appear in the middle of the bars and it looks ugly and confusing. I intended for the price to jump from bar to bar I attached a screenshot for you to understand the situation |
Screenshot 2023-10-26 212936.png / V - Attached On 2023-10-26 20:40:54 UTC - Size: 34.89 KB - 81 views |
[2023-10-27 14:13:44] |
John - SC Support - Posts: 36300 |
You need to expand the scale if you want to have each price tick show up in the scale. Refer to the following: Chart Scale and Scale Adjusting: Interactive Scale Range - Expand/Compress Scale Also, you can force a specific increment by setting the option for "Scale Increment" to what you want to have - but this may still require expanding the scale if there is not enough room to show every price tick within the selected range. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
