Date/Time: Tue, 26 Nov 2024 18:41:48 +0000
Update
View Count: 280
[2023-10-26 19:45:38]
User359177 - Posts: 1
I had a new computer build August, 2022 which I saved for a back-up with a copy of Sierra Chart transferred to it from my current computer back then. Since Aug, 2022, the back-up computer has been sitting idle, not in use for the past 14 months. I will start using it in the coming weeks. Can I just run a current update on it or are there other issues I need to be aware of? Thank you, BFR
[2023-10-27 04:59:36]
Sierra_Chart Engineering - Posts: 17182
Yes you can run a current update. Instructions:
