Date/Time: Tue, 26 Nov 2024 18:42:31 +0000
chart replay issue
View Count: 409
[2023-10-26 15:56:38] |
User531621 - Posts: 91 |
Hello! For some reason the last 2 times i play the replay, a box pops up and asks about the processing time in seconds before i hit the play button. Never saw this before and i think it is messing up the smooth movement of the replay. And my buys and sells dont show up. Sound familiar? How do i fix this. Thank you
[2023-10-26 16:58:22] |
John - SC Support - Posts: 36300 |
The query for the "Processing Time in Seconds" will come up whenever you are running a replay for multiple charts and using any of the replay types other than "Standard Replay". The following is from the documentation for replays: When there is a multiple chart synchronized replay, the amount of time of data which is processed in each chart at a time, is prompted for when the replay is started during a multiple chart synchronized replay with the Enter Processing Step in Seconds prompt. This also applies when using the Calculate at Every Tick/Trade Replay Mode. Therefore, if you use a processing step of 5 seconds, then 5 seconds of trades will be processed at once before the next chart is processed.
[2023-10-26 18:39:37] |
Thank you, but i only have 1 chart on replay. Please advise, thank you so much |
[2023-10-26 19:23:51] |
You should not be getting that prompt if you are only replaying a single chart. Please get us a screenshot of your Replay Window with the prompt for "Processing Time in Seconds", as we are very confused. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-10-26 21:23:01] |
I think i figured it out! It was on the "Accurate trading system back test mode", and put it on the "Standard Replay". That fixed it! Thank you so much |
