Date/Time: Tue, 26 Nov 2024 18:42:57 +0000
Activate Free trial sms text to mobile device issue
View Count: 245
[2023-10-26 15:51:48]
WaveSave888 - Posts: 1
how do I save my numbers bars chart study on one window as a template to apply to other new Chartbooks and symbols?
[2023-10-26 15:53:43]
John - SC Support - Posts: 36300
There are a couple of options:
1) Save the Numbers Bars Defaults as you want them. Then whenever you apply the Numbers Bars study to a chart it will have those defaults. Refer to the following:
Chart Studies: Using Custom Default Study Settings
2) Save the Numbers Bars study as you want it as a Study Collection. Refer to the following (make sure you are aware of the option to ask if you want to remove other studies):
Study Collections
