Date/Time: Wed, 30 Oct 2024 22:55:56 +0000
Clock issue
View Count: 941
[2014-07-21 14:05:22] |
rubicon - Posts: 19 |
computer clock is correct. SC is not in sync. Chart Settings is set at 9:30 Todays 1st bar shows 13:01 Any thoughts as to why? Thanks in advance... I changed bthe time zone BUT the first bar prints at 12:32 instead of about 9:30 I`ll keep looking Date Time Of Last Edit: 2014-07-21 15:46:03
[2014-07-21 17:38:44] |
Refer to help topic 38 here: Http://www.sierrachart.com/index.php?page=doc/helpdetails38.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
