Date/Time: Tue, 26 Nov 2024 19:13:50 +0000
Instances to run on startup: 3, but only 1 subinstance is started
View Count: 245
[2023-10-26 13:40:53]
User695518 - Posts: 53
Its been awhile since I tried subinstances. I thought I would give it a try. I am running 2555. I can to to File | New Instance and create two subinstances with no problem. But if I set Instances to Run on Startup to 3, I only get 1 subinstance to run.
Before taking the screenshot, I cleared out the previously created subinstance folders. Then I restarted SierraChart. Only subinstance 3 folder is created.
imageinstances.png / V - Attached On 2023-10-26 13:38:00 UTC - Size: 63.23 KB - 68 views
[2023-10-26 13:59:19]
Sierra_Chart Engineering - Posts: 17182
Make sure you understand that setting. Refer to:
General Settings Window: Instances to Run on Startup (Global Settings >> General Settings >> General >> New Instances)
[2023-10-26 14:04:05]
LOL, thanks... like I said.. its been awhile..
