Date/Time: Tue, 26 Nov 2024 19:46:13 +0000
Renko Chart Discrepancy
View Count: 243
[2023-10-26 11:42:31]
user_xyz - Posts: 416
I have two Renko charts, one in main instance and another in sub-instance. They are identical, all Chart Settings are the same (session times, tick size, etc) yet the data is different across the charts.
I was comparing the Renko Bar Predictor and values are different, then noticed the opening Renko Bar in the after hours session has different high, low, open, last values. Can you point me in the right direction to correct this?
Private File
[2023-10-26 14:02:22]
Sierra_Chart Engineering - Posts: 17182
Refer to:
Working With Charts: Resolving Differences of Chart Bars Between Charts
