Date/Time: Tue, 26 Nov 2024 19:47:54 +0000
[User Discussion] - Rithmic replay - Price Ticking Problem ?
View Count: 364
[2023-10-26 07:19:01]
User923660 - Posts: 1
I have a problem with displaying the price during replay on rithmic data.
If I use data that does not have full market depth, everything is fine. The price ticks inside the bar, but if I use data with full market depth, the bars simply jump without ticking inside.
Everything is always used on the same chart without adjustment. The conditions are identical.
This problem does not appear with "denali" data, there the price ticks inside the bar on replay and at full depth correctly.
Is it a setup problem or a technical problem with sierra ?
p.s.: The data was saved during live operation ...
Thanks for your help - directions ......
Igor
[2023-10-26 15:11:51]
Sierra_Chart Engineering - Posts: 17182
Set Sierra Chart to a Tick by Tick Data Configuration. Follow the instructions here to do this:
