Date/Time: Tue, 26 Nov 2024 15:36:02 +0000
Arbitrage Entry and Exit Tools
View Count: 334
[2023-10-25 14:19:33] |
Le Dharma - Posts: 73 |
Hey Sierra, I had a few questions. 1). The TFAP (flatten all positions - all accounts) Only works on Live orders. Could you consider expanding this tool to work on Sim positions as well? 2). The Tool Spread Order Entry Study is complex, (has no multiplier), and I need to simplify it. Does this kind of project require any kind of special knowledge of acsil? Could you recommend programmers who could create a tool that Simultaneously enters two different symbols? 3). The Custom Symbol Charts are an excellent feature from Sierra. Unfortunately they are historically short. What kind of coding would be involved in expanding the history of these Custom Symbol charts? I suspect this project would be very complicated. Could you recommend some programmers who would be able to expand the length of the Custom Symbol Charts? Thanks Sierra!! I hope you have a good week. -Ben Date Time Of Last Edit: 2023-10-25 14:21:50
[2023-10-25 15:14:49] |
John - SC Support - Posts: 36295 |
1. We have added this as a Feature Request - just keep in mind that we can not say when we would get to any particular request. 2. Refer to the list of programmers at the following link: List of Third Party Sierra Chart Study and System Programmers 3. This is an internal calculation, so an outside programmer is not going to have access to how the current mechanism works. They would have to create an entirely new system to create the data. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-11-13 16:33:12] |
Sierra_Chart Engineering - Posts: 17182 |
3. Do not involve a programmer in this. That is not going to help at all. Refer to: Custom Calculated Symbols: Resolving Missing Historical Data Issue Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
