Date/Time: Tue, 18 Feb 2025 23:08:07 +0000
How to change colors For borders for control Bar and the charts windows
View Count: 297
[2023-10-25 01:31:20]
CircuitWanderer - Posts: 15
Do not if you can see the snap shot I took, But I am trying to change the borders for the control bar and the windows for the entire sierra chart
imageScreenshot 2023-10-24 182041test.png / V - Attached On 2023-10-25 01:29:40 UTC - Size: 198.33 KB - 101 views
[2023-10-25 12:07:24]
DFromeaux - Posts: 10
These colors have nothing to do with Sierra Chart but with the Windows theme you're using.
Unfortunately, it's impossible to modify these colors in Windows without using third-party software. I don't have any recommendations as to which software to use to change these colors as I don't do it myself, but perhaps someone else will have some advice on this subject for you.
Have a nice day.
[2023-10-25 12:22:39]
Thank you for the feed back.
