Date/Time: Tue, 26 Nov 2024 20:02:29 +0000
Blurry price when in red
View Count: 259
[2023-10-24 18:07:25] |
Poparocks - Posts: 15 |
Not sure what happened here cause it didn't look like this before. Now when the number is negative or in red, also for PnL's, it comes out blurry. If in green or neutral it is fine and clear. How do I fix this?
Capture2.PNG / V - Attached On 2023-10-24 18:07:07 UTC - Size: 1.56 KB - 72 views |
[2023-10-24 20:54:40] |
John - SC Support - Posts: 36307 |
In the image you provided the number highlighted in red appears to us to be perfectly fine. When you look at the same image, does the number appear to correct or blurry to you (we are wondering if it is the image that is correct and your screen is still off somehow or if it is a personal thing).
[2023-10-25 00:38:20] |
Sierra_Chart Engineering - Posts: 17182 |
Try a different color.
