Date/Time: Tue, 26 Nov 2024 19:37:50 +0000
P/L display in trade window
View Count: 221
[2023-10-24 15:03:01] |
Boris Libman - Posts: 58 |
In chart settings, I'm using a different trade symbol (MES) form primary symbol (ES). My understanding is that this will run an ES chart but execute in MES. With a trade window open adjacent to the chart however, the p/l is displayed using ES multiplier (not the MES that is being executed). Is there a setting to toggle this so that the p/l matches the symbol being executed (in this case MES)?
[2023-10-24 15:22:40] |
John - SC Support - Posts: 36302 |
Refer to the following: Chart Settings: Updating Currency Value per Tick for Trade Symbol For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
