Date/Time: Wed, 27 Nov 2024 02:36:53 +0000
Inside Bar Alert
View Count: 1325
[2014-07-21 11:44:36] |
infpz - Posts: 826 |
There is a study called inside bar - if I wanted to have an alert if this condition were true, what would the simple alert code be for such a thing? The inside bar study would be ID.SG1. Thank you. PZ |
[2014-07-21 13:52:43] |
Use this formula: =SG1>0 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
