Date/Time: Tue, 26 Nov 2024 19:56:18 +0000
Numbers Bars Calculated Values / Color background based on %
View Count: 261
[2023-10-23 21:55:02]
User347921 - Posts: 39
Hi, I'm using Numbers Bars Calculated Values for Cumulative Delta table. The color background Base don Value Percentage is set to "YES", and the Max/Min are based on "Daily Data". However, I don't understand which are the Max and Min values for coloring the Bar Delta (SG1). I thought the % and coloring are based on SG1/SG8 and SG1/SG9, but apparently it's not the case. Can you please indicate how the % coloring is calculated? SG1 divided by what exactly? Thanks
[2023-10-24 14:10:49]
John - SC Support - Posts: 36306
The information for how the coloring is done is all described at the following link:
Numbers Bars: Calculated Values Background Coloring Logic
