Date/Time: Tue, 26 Nov 2024 19:53:38 +0000
Spreadsheet system for trading / autofill column
View Count: 247
[2023-10-23 17:09:02] |
User669983 - Posts: 3 |
Dear support team, while using the spreadsheet system for trading it sometimes happens to me that the column for the formula doesn't autofill. See screenshots. Can you please give me a hint what might be the reason for this behavior and how to avoid it? thank you. https://www.sierrachart.com/image.php?Image=1698080666276.png https://www.sierrachart.com/image.php?Image=1698080734687.png |
SC20231023_1.JPG / V - Attached On 2023-10-23 16:57:11 UTC - Size: 116.62 KB - 80 views SC20231023_2.JPG / V - Attached On 2023-10-23 16:57:18 UTC - Size: 97.04 KB - 82 views |
[2023-10-23 17:36:26] |
John - SC Support - Posts: 36305 |
Usually when this occurs it is because the particular sheet is either not the formula sheet (look at the information in cell D1 to see what it states the Formula Sheet is for this sheet), or the sheet is not part of a Spreadsheet System for Trading and therefore is a standard sheet. In terms of the latter - make sure that the sheet that is called out in the Inputs for the Spreadsheet System for Trading is the sheet that you are working on (Sheet16). For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
