Date/Time: Tue, 26 Nov 2024 19:44:00 +0000
Swing High and Low Arrow Up and Down Alert
View Count: 249
[2023-10-23 08:40:22] |
User160486 - Posts: 40 |
How do you set an alert on candle close for swing high and low arrow up and down? what is the formula? Thanks.
[2023-10-23 15:31:52] |
John - SC Support - Posts: 36302 |
If you are just wanting an alert when the arrow is drawn and when the bar is closed, then your formula would be the following: =ID1.SG1 You would need a separate alert for the Swing Log. If you want the same alert for either Swing High or Swing Low, then it would be: =OR(ID1.SG1, ID1.SG2) Where ID1 is the ID of the Swing High/Low study and SG1 is the subgraph for Swing High and SG2 is the subgraph for Swing Low. You would also then set the option for the alert of "Evaluate on Bar Close". For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
