Date/Time: Tue, 26 Nov 2024 11:42:18 +0000
TPO chart, Opening Range not correct for Weekly Profile
View Count: 386
[2023-10-23 00:13:02] |
joshtrader - Posts: 488 |
I take a standard daily TPO chart with the standard 30 minutes as the TPO length. I change the profile to be Weekly. I would like to highlight the first 60 minutes of the week as the opening range. However, the setting seems to have no effect. The value is accepted, but the opening range highlight seems to be only the first minute, not the first 60 minutes as I would expect.
[2023-10-23 01:47:12] |
Sierra_Chart Engineering - Posts: 17179 |
Provide this chart by following these instructions: Support Board Posting Information: Providing Chartbook with Only a Single Chart So we can look at it. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-10-23 01:47:37
[2023-10-23 18:57:06] |
Attached, thank you
Private File |
[2023-11-27 05:52:43] |
We understand the reason for this problem and we will implement a solution. It has to do with the fact that the way your TPO Profiles are configured, the actual internal starting Date-Time is earlier than Sunday evening, Saturday, and the opening range ending time is in that prior day. We will work out a solution for this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-11-30 18:40:26] |
We have made a change to resolve this in version 2566.
