Date/Time: Wed, 27 Nov 2024 04:56:33 +0000
derived data chart with different x-axis or display non-volume profile on chart
View Count: 1229
[2014-07-20 22:03:08]
umair1 - Posts: 86
Is there a way to produce a chart using acsil where the x-axis is not time? See my attached graphic. I apologize for the poor paintbrush art.
If not is there a way to produce a profile- similar to a volume profile but where the data being represented is not volume and is data generated by the user instead? I would use the profile on a secondary chart (not the main price graph) so the y-axis would represent the count (referring to my graphic).
Date Time Of Last Edit: 2014-07-20 22:03:30
imagecount.png / V - Attached On 2014-07-20 22:03:25 UTC - Size: 5.52 KB - 374 views
[2014-07-30 02:25:54]
You can create custom charts in Sierra Chart, you can draw various objects on charts using the drawing tools, and also directly access the chart window to do free form drawing. Refer to the following for information about all of this:
https://www.sierrachart.com/index.php?page=doc/doc_ACSIL_Members_Variables_And_Arrays.html#scIsCustomChart
https://www.sierrachart.com/index.php?page=doc/doc_DLLTools.html
https://www.sierrachart.com/index.php?page=doc/doc_ACSILProgrammingConcepts.html#CustomFreeFormDrawing
We apologize for the delay, we just needed time to concentrate on this and do some documentation updates.
Date Time Of Last Edit: 2014-07-30 02:27:16
