Date/Time: Tue, 26 Nov 2024 19:57:48 +0000
Attached OR Bracket Orders for Multiple Symbols
View Count: 224
[2023-10-22 15:58:40] |
Le Dharma - Posts: 73 |
Hey Sierra. I'd like to place an order where I am I entered into two different assets at the same time. If I'd like to trade gold and silver at the same time, does Sierra have a Button or Order type that can create an order in two symbols simultaneously? |
[2023-10-23 00:11:23] |
Sierra_Chart Engineering - Posts: 17182 |
The closet available is the Spread Order Entry study: Spread Order Entry Study Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-10-23 15:27:09] |
I might be misunderstanding how to use this study... But I think the study is missing a multiplier for the Legs. I'm looking at the spread different graph which the legs create, and the spread does not match The Custom Chart I have created. If I'm not mistaken, this study was created for calendar Arbitraging between the same symbols. Could you add a multiplier input for the Legs, so that we can alter one of the symbols? In this way, the symbols can match up better, even if they have very different Y-Price Values. |
