Date/Time: Tue, 26 Nov 2024 20:25:55 +0000
Bug.: Text-coordinates shift relatively to a chart's drawings upon window resizing.
View Count: 234
[2023-10-22 15:51:35]
User408639 - Posts: 69
Moin Moin.
As You said, that You are going to redesign the windows' libs anyways.:
Here is a little bug regarding the relative coordinates.:
1. Placing some text into a window with more than one study-area,
2. will be moving the text relatively to the drawings, to which it had been aligned,
3. simply upon resizing the window.
My impression is, that the coordinates are correctly calculated, if there is but one area, into which the studies are inserted by SC.
But if an additional study is using its own space (, i.e., is not overlaid), then SC does still use the "whole window"'s coordinate-system instead of the one of the study's area, where the text had been placed in.
_Tschüß,
__Michael.
Date Time Of Last Edit: 2023-10-22 15:53:30
imagetext positioned as planned.png / V - Attached On 2023-10-22 15:51:20 UTC - Size: 47.45 KB - 82 views
imagetext re-positioned after window-resizing.png / V - Attached On 2023-10-22 15:51:25 UTC - Size: 77.16 KB - 75 views
