Date/Time: Tue, 26 Nov 2024 20:13:12 +0000
Transferring all preferences to another computer
View Count: 304
[2023-10-22 15:29:44] |
User216960 - Posts: 6 |
I want to know what files control preferences that I have set up on a previous copy of Sierra. Can i just copy over and replace most of the files under "SIERRA CHARTS" to the new computer? Or just specific files that contain the setups, settings and keyboard shortcuts etc.?
[2023-10-22 18:34:07] |
Sierra_Chart Engineering - Posts: 17182 |
This is explained here: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-10-22 18:34:31
