Date/Time: Wed, 27 Nov 2024 02:28:44 +0000
Number of Formula Columns
View Count: 1292
[2014-07-20 20:18:13] |
User53601 - Posts: 105 |
Hello, I have set up the input "Number of formula columns" in the spreadsheet to max value (60). However, I cannt find the added columns in the sheet. As of AB column the columns are dedicated to other studies data. I cannt see any free columns neither after the last column dedicated to other studies data. |
[2014-07-20 20:21:11] |
If you are using 60 formula columns, the first study will appear in column BT. Column AB will still contain the old study data. Select the header of that column and press the Delete key to delete the existing data there. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-07-20 21:10:51] |
I see, thank you. Jaro |
