Date/Time: Tue, 26 Nov 2024 20:04:04 +0000
Playback for 2007 ES Tick data
View Count: 398
[2023-10-21 20:37:13] |
User478380 - Posts: 184 |
Hi, This may sound a bit weird but its really quite important. Is there a way to download ES TICK data for Jan 10th 2007 please and run a playback on tick charts for that day? If this is not available in Sierra, do you know of another way I could do this please ? Many thanks, |
[2023-10-23 02:07:11] |
Sierra_Chart Engineering - Posts: 17182 |
Try the symbol: ESH07 Set Sierra Chart to a Tick by Tick Data Configuration. Follow the instructions here to do this: Tick by Tick Data Configuration Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-10-23 02:53:28] |
Thanks. Were u able to actually load a tick chart please for esh07?
[2023-10-23 03:06:31] |
We tested now. No data for that symbol.
[2023-10-23 03:21:40] |
So how can I load a tick chart for 2007? Is there any other way u can suggest please?
[2023-10-23 03:45:18] |
You can get the data here: https://www.tickdata.com/historical-market-data-products/futures-data/available-futures-data/ And import it: Exporting and Importing Intraday Data Files Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-10-23 11:19:17] |
Hi - thanks for that. So are you saying if I get the data from that link, I will be able to import it into sierra charts please? Also, can you suggest any cheaper data providers please ? Date Time Of Last Edit: 2023-10-23 11:45:54
[2023-10-25 14:25:38] |
Hi - thanks for that. So are you saying if I get the data from that link, I will be able to import it into sierra charts please? You need to check on this. You need to make sure they support data in a format supported by Sierra Chart. Refer to the supported formats here:Exporting and Importing Intraday Data Files We do not know anyone else who has the data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-10-25 14:26:01
