Date/Time: Tue, 26 Nov 2024 20:38:09 +0000
ACSIL AddAsUserDrawnDrawing replay mode
View Count: 274
[2023-10-21 12:35:44]
User453167 - Posts: 5
my study is printing specific volume values on my chart using sc.UseTool. I've noticed that during recalculations, all drawings are removed unless AddAsUserDrawnDrawing = 1. Now, all drawings persist and cannot be deleted. When i switch into replay mode, all drawings generated ahead of the replay time are already displayed on my chart. I just want to see the drawings that were generated before the point in time where the replay starts.
Is there a function in ACSIL which detects replay mode?
Or do i have to work around this manually somehow. Can i then use sc.DeleteUserDrawnACSDrawing for this?
Date Time Of Last Edit: 2023-10-21 12:39:33
[2023-10-21 15:45:28]
Sierra_Chart Engineering - Posts: 17184
Really the proper way to do this is to not use AddAsUserDrawnDrawing = 1 and when there is a full recalculation which can be detected with:
sc.IsFullRecalculation
You then will add all of the drawings which should be added.
Or you do need to delete the drawings with sc.DeleteUserDrawnACSDrawing during a full recalculation.
You know what you want to accomplish. So you have to work out the details.
[2023-10-21 16:04:37]
thank you very much for pointing me into the right direction. everything works now as intended.
have a great day
