Date/Time: Tue, 26 Nov 2024 20:12:19 +0000
live trading
View Count: 286
[2023-10-20 15:31:58] |
User638676 - Posts: 13 |
Hello, How can I use Sierra charts to trade with real currency? Do I need a broker? if no - how exactly does it work if yes: Do you have a list of companies (brokerage firms) whose accounts can use Sierra charts to trade from directly? Which Sierra service would I need for live trading US Equity S&P 500 Futures (ES)? Is there any other information I may need to know before considering trading live? There's no rush but I have to start thinking about this as I am progressing with my simulation. Please help however you can Thank you kindly greg |
[2023-10-20 17:00:35] |
John - SC Support - Posts: 36307 |
Yes, you need a broker to trade from Sierra Chart. We are not a broker. If you are only trading the CME Group, then we recommend a broker that supports our Teton Order Routing Service. You will find the information for this service at the following link with a list of brokers at step #2 of the Setup Instructions: Sierra Chart Teton Futures Order Routing In order to use Sierra Chart for live trading, you need to be on one of the "Integrated" packages. Refer to the information at the following link: Description of Service Packages and Pricing: Integrated Packages For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
