Date/Time: Tue, 26 Nov 2024 20:25:17 +0000
Keyboard shortcut to place buy limit order one tick above previous high
View Count: 305
[2023-10-20 14:06:17]
User956467 - Posts: 30
Hi. I would like to be able to use a keyboard shortcut to place a buy limit order one tick above the previous bar high. And the opposite for a sell limit. Is this already available? Or is there someone out there who code this for me? Thanks very much.
[2023-10-20 16:19:24]
John - SC Support - Posts: 36307
You can use the Spreadsheet System for Trading to put the Limit (which you would probably want as a Stop Limit) order where you want it. But there is not a way to use a keyboard shortcut to manage the on/off for that system.
The other built-in systems do not offer the Limit/Stop-Limit options, but do have the keyboard shortcut capability to turn the system on/off.
It would probably be easiest to modify the "Trading System Based on Alert Condition" study to change the order type. This study is in the file TradingSystemBasedOnAlertCondition.cpp in the ACS_Source folder under your main Sierra Chart installation folder.
You can also find a list of potential programmers at the following link:
List of Third Party Sierra Chart Study and System Programmers
