Date/Time: Wed, 27 Nov 2024 02:35:22 +0000
Bug in preRelease version 1162
View Count: 1201
[2014-07-20 10:08:05] |
sampater - Posts: 244 |
After used the "Chart Settings" then size of chart regions are go wrong (changed size). Marek |
[2014-07-20 17:04:25] |
We are fixing this now.
[2014-07-20 18:33:17] |
Update Sierra Chart by selecting Help >> Download Prerelease. We have uploaded a new revision which solves this.
[2014-07-20 19:37:23] |
Thanks, it's work fine. Marek |
