Date/Time: Tue, 26 Nov 2024 20:41:21 +0000
Engineering: s_UseTool RetracementLevel Show/Hide
View Count: 296
[2023-10-19 17:41:12] |
User92573 - Posts: 530 |
Dear Support/Engineering, Please would you consider adding Show/Hide to the "s_UseTool RetracementLevel" so that we can control the default settings for the check box from Study ACSIL. Setting to 0.0f as suggested just overlays multiple lines/colors etc. at 0. Many thanks. Date Time Of Last Edit: 2023-10-19 17:42:43
[2023-10-19 18:44:37] |
Sierra_Chart Engineering - Posts: 17184 |
This is already supported. Refer to: Using Drawing Tools From an Advanced Custom Study: s_UseTool::RetracementLevels[] Using a value of FLT_MAX at a particular index in the RetracementLevels[] array means that level will not be drawn. Subsequently setting that level to any other value will restore the level to that particular value.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-10-19 18:44:47
[2023-10-20 10:35:41] |
Thank you, but using FLT_MAX removes the level completely just like commenting out the code.
I'd like to leave the levels there in case required and just as in the SC Tools, simply set the check box to initially checked/hidden. Then all levels can be Hidden/Shown as required. Many thanks. Date Time Of Last Edit: 2023-10-20 10:44:10
