Date/Time: Sun, 24 Nov 2024 16:34:00 +0000
Question: 'Descending Display Order' in Trade Activity Log
View Count: 348
[2023-10-19 16:08:34]
Tony - Posts: 516
in 'Trade Activity Log' window:
Edit --> Descending Display Order
It seems that it only work with 'Trade Activity' tab, is there
a way to do the same with 'Trades' tab?
Thanks.
[2023-10-19 18:21:32]
This works with the [Trades] tab. We are not seeing any issue when we select this option - the data updates as expected on that tab.
[2024-05-14 15:39:46]
Tony - Posts: 516
Just to follow up, I thought it was WINE issue, until recently, I installed Sierra in Windows 10, I still have the same issue, the list under [Trade Activity] is in descending order, but the list under [Trades] still in ascending order. (version 2634)
Not sure what I missed.
Date Time Of Last Edit: 2024-05-14 15:40:21
[2024-05-14 21:26:21]
If you have the option for "Edit >> Flat to Flat Display for Trades List" enabled, then the "Descending Display Order" will not work on the Trades page.
