Date/Time: Tue, 26 Nov 2024 20:27:57 +0000
Order location on DOM vs Chart DOM
View Count: 569
[2023-10-19 13:58:46] |
TopGunTrader - Posts: 172 |
Hi, I like how chart DOM's have the orders farther away from price on LEFT side with dotted line in between. On regular DOM they are right on RIGHT side of chart which I have up volume profile showing numbers of bids/offers and the orders often are on top of them. I wish in DOM to duplicate how they look on Chart DOM but can't figure out how to do this. It's main reason I don't use regular DOM. Can this be done and if so how? |
[2023-10-19 18:10:32] |
John - SC Support - Posts: 36307 |
We are not quite sure we understand exactly the items you are referencing, but you can certainly get the Chart DOM and the Trading DOM to be setup the same way. It sounds like your main issue is the locations of the columns. These can all be changed. Refer to the following: Global Trade Settings Windows: Move Up/Left (Trade >> Customize Chart/Trade DOM Columns) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-10-19 18:54:08] |
DF52 - Posts: 19 |
TG, If I'm understanding you... Some settings I have in the menus are as follows: Select the Trade DOM>Chart Settings>Trading>Visual> Align Trade Drawings Text to Right - No Trade Drawings Left Align % - 100 TBH I'm not sure whether the one about aligning text to right makes any difference. But the 'Trade Drawings Left Align %' does move the order somewhat over to the left in the DOM, which then makes VAP bars a bit more visible, assuming you have them to the right. |
