Date/Time: Tue, 26 Nov 2024 16:27:13 +0000
[User Discussion] - Single Horizontal Lines file for multiple lines
View Count: 481
[2023-10-19 13:28:31] |
User360283 - Posts: 504 |
I have 5 charts in my chartbook I use the Horizontal Lines study to record and display info. This means I must update 5 Horizontal Lines studies several times every day! How can I have 5 charts use a single Horizontal Lines study? Thanks |
[2023-10-19 13:44:59] |
John - SC Support - Posts: 36300 |
There is the option to "Link" the studies between charts. The only issue with this is that it applies to all the studies on the charts. So if you just use the Horizontal Lines study, then this would work well for you. Refer to the following: https://www.sierrachart.com/index.php?page=doc/ChartSettings.html#LinkNumber Otherwise, you may want to just use the Horizontal Line drawing tool and have that copied to the other charts. Refer to the following: Chart Settings: Copy Chart Drawings from Chart #'s (Chart >> Chart Settings >> Chart Drawings menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-10-19 13:51:09] |
User584084 - Posts: 262 |
This is what I use for horizontal levels. https://www.simplesystemtrading.com/autolevels/ |
[2023-10-19 14:47:20] |
This is a request for an improvement! It can't be vert hard for the Sierra programmers to do this Please allow a single horizontal lines study to be used /referenced by multiple charts in one chartbook. Please Thanks |
[2023-11-10 17:24:06] |
I have using Sierra for more than 20 years! And Sierra has NEVER implemented one of my improvement requests! Insane |
[2023-11-10 18:18:50] |
User719512 - Posts: 264 |
Did you not see John's reply about copy chart drawings? You can already do this today.
Sierra Copy Chart Drawings.png / V - Attached On 2023-11-10 18:18:08 UTC - Size: 344.52 KB - 58 views |
[2023-11-10 18:30:13] |
User431178 - Posts: 543 |
Also, if horizontal lines study is the preferred option, use study/price overlay - Study/Price Overlay Study Only need horizontal lines study on one master chart, all the editing is done on one chart, then study/price overlay on all other charts where lines are required. |
