Date/Time: Thu, 24 Sep 2026 15:32:50 +0000
Unable to delete all s_UseTool items
View Count: 1038
[2023-10-19 13:02:39]
User907967 - Posts: 54
Hi, I am keen to find out why I can't seem to be able to delete all the drawings upon study closure (all at once).
The function that triggers the deletion:
  int i = 0;
  s_UseTool j;
  while (sc.GetUserDrawnChartDrawing(sc.ChartNumber, DRAWING_UNKNOWN, j, i)) {
    sc.DeleteUserDrawnACSDrawing(sc.ChartNumber, j.LineNumber);
    i++;
I run the above when the below happens:
if (sc.LastCallToFunction == true)
Every time I do that, there are several drawings still left on the chart.
What am I missing? Is this a bug?
Before you ask, I need to be able to copy these drawings on other charts so I can only use user drawings.
Thoughts?
[2023-10-19 13:34:10]
User907968 - Posts: 884
Yes, it is a bug in your code.
i++;
You are deleting an item from the index, but still incrementing, therefore every other drawing is skipped over.
The increment is not needed if the call to delete is successful.
[2023-10-19 13:41:52]
Thank you so much. You are right. I should have realised that.
