Date/Time: Tue, 26 Nov 2024 20:40:40 +0000
multi-timeframe
View Count: 259
[2023-10-19 03:03:29]
User454054 - Posts: 29
HI,
How to make a multi-timeframe in the same screen?
[2023-10-19 13:13:43]
John - SC Support - Posts: 36307
You need to have separate charts in order to have different time frames. You can tile the charts in different methods by selecting the options under the "Window" menu. Refer to the information starting at the following:
Window, CB and CW Menus: Cascade (Window)
There is also the option to "detach" charts and have them as separate windows. Refer to the following:
Window, CB and CW Menus: Detach/Attach Window (Window)
