Date/Time: Tue, 26 Nov 2024 20:15:21 +0000
[Programming Help] - sc.selectedtradeaccount strange behaviour
View Count: 263
[2023-10-18 17:17:06]
User987654 - Posts: 69
If this falls outside of Sierra Support, I understand and please move it to "Submit as programming help".
If not, this is the behaviour I am seeing.
If I open up 2 sub-instances and I have 2 trading accounts with the same clearing firm and trading the same contract (CL). In the 1st sub-instance if sc.selectedtradeaccount="acct2", then after charts load "Trade Window for Chart" will show the account to be "acct2", which is correct. After this, I go to 2nd sub-instance and load acsil study where sc.selectedtradeaccount="acct1" but after the charts load "Trade Window for Chart" will not show "acct1", instead shows "acct2", which is wrong. In this case, I am setting the sc.selectedtradeaccount in sc.SetDefaults{}.
I've tried setting it in if(sc.index==0 && sc.IsFullRecalculation==1){} but when I do this, if the chart the study is on references a study from another chart, it will endlessly reload once I open the "Trade Window for Chart". This method, however, does set the account properly for both instances.
Teton routing with denali feed
Windows Server 2016
Date Time Of Last Edit: 2023-10-18 17:51:33
[2023-10-19 14:16:09]
Sierra_Chart Engineering - Posts: 17182
This does not make sense for the chart to be reloading when opening the Trade Window:
There is some other reason for this:
High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often: 30.3 - Charts Reloading Often
