Date/Time: Fri, 18 Oct 2024 06:17:55 +0000
TD Sequential / trading indicator that uses a 13-bar countdown to signal trend reversal
View Count: 373
[2023-10-18 12:44:10] |
SSGill - Posts: 36 |
Hello; I found the DeMark indicator called trading the nines, under studies. But I understand it is only the first part of the system, the second part uses a 13 count sequence, and should be used in conjunction with Trading the Nines study. Can anyone point me to where it is? ** and a thank you to Tom for producing the above indicator!! |
