Date/Time: Tue, 26 Nov 2024 20:16:55 +0000
Futures exchange traded spread not available: AREV23-NYMEX
View Count: 301
[2023-10-18 10:02:12] |
User423915 - Posts: 15 |
Hi, I'm unable to download historical data for exchange traded spreads. For instance, when I select the spread AREV23-NYMEX in the NYMEX list I get the error: 'Download failed. Error downloading historical data'. Do I need a special subscription for this data? |
[2023-10-18 22:53:47] |
Sierra_Chart Engineering - Posts: 17184 |
We will check on this.
[2023-10-19 13:50:04] |
We are not getting that error, and you should not. However, there just is no trading in these spreads: https://www.cmegroup.com/markets/energy/refined-products/rbob-crack-spread-swap-futures.settlements.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-10-19 13:50:19
